LarQ98V
    20
  • Website URL
    http://
    Belguim
LarQ98V's Achievements
  1. Pm mate
  2. Hi, As the title suggests i am looking for top mounts for my glanzas front shocks. Must be in good con (no rust) and i will consider tein or cusco pillow ball ones also. If anyone's got any let me know
  3. Hi mate, driveshafts from lsd or non?
  4. Hi all, My shock went bang the other day after i hit a sink/pot hole, so i decided to replace the both the fronts while i was at it. I managed to get the passenger out but when i went to remove the drivers side one of the nuts is just spinning but not loosening. Its one of the 3 small nuts that connect the shock to the body.from the top mount. The two that connect the strut bar come off easily but the other one wont budge.
  5. Damn! just what i was gona ask for. Ill try toyota. How much for the passenger door handle mate? mines snapped.
  6. LarQ98V
    Rear pads
    Alright mate, went at the pads today myself but couldnt get the rear caliper open to take the pads out. What do you have to open to get access to them? Scratch that, just needed a bit more elbow grease.
  7. LarQ98V
    Live Wire
  8. LarQ98V
    Live Wire
    alright, cheers for the heads up My electrical knowledge is basic so i might have to get someone to do it 4 me in that case. Seems a bit complicated.
  9. LarQ98V
    Live Wire
    Hi, I'm tryin to find out which wire at the cig lighter is the live. I've tried using a circuit tester but i doesn't light up on either of them. There's a grey wire and a white&black striped wire. Any help would be great as i've got mot tomorrow and need to wire this fog.
  10. LarQ98V
    Speedo
    Got it sorted, cheers nyway
  11. LarQ98V
    Speedo
    I was changin the fascia on the clocks earlier and accidently turned the speedo needle backwards. Now it only goes up to about twenty miles an hour and stops dead. Any ideas?
  12. Thinkin bout gettin a set of 16" RS5's for my V, does anyone know what they weigh and will they sap too much power?
  13. Good good , only a standard exhaust system at the moment....one plus point of it i suppose!
  14. Cheers fellas Mite just fit the kit in the original air box position for the time being....cash is abit tight.
  15. Just got a monstermotor air filter relocation kit and have heard boost creep can be a problem wit these....anyone experienced this wit this fitted?
