AStyle
    8
AStyle's Achievements
  1. by SWAP AEM and garrett do a detailed report with a full sheet of tunings
  2. 2007-2008 ДВИГАТЕЛЬ: 4E-FTE Ct-9 Blitz Induction Kit TRD Engine Mount Set Ohlins Engine Torque Damper Denso VK20 Apex'i Exhaust System Camshafts 300 in/ex SARD R2D2 SARD Aluminium radiator SARD Radiator Breather Tank N-TypeD Greddy Oil Catch Tank Trust Oil Cooler Kit No Name Sport Radiator Hoses Samco Silicone Hosing МКПП С56 AStyle Quick Shift ПОДВЕСКА: Tein Type Flex Coilovers TRD Suspension Bush: Lower arm brush No.1, Lower arm bush No.2, Rear suspension arm bush TEIN EDFC Controller Kit Universal CARBING Front Tower Bar Cusco 40mm Carbon Rear Strut Bar Type CB Whiteline Adjustable Lateral Rod Urethane Bushing Whiteline Adjustable Panhard Rod ТОРМАЗНАЯ СИС-МА Cusco Brake Cylinder Stopper AStyle Sumitomo 4-Pot Front Caliper Kit TRD Direct Brake Lines Removed system ABS ЭЛЕКТРОНИКА: DEFI BF- series ИНТЕРЬЕР и ЭКСТЕРЬЕР: Duralumin Lock Nut Set Red Short Type 4-Lug Ремни Takata 2шт. Каркас Cusco Safity21 Zep Racing Live Sports Body Kit 2009-2010 5e-hfe Kkk24 2011-2012 Ct-9/12 Blitz Induction Kit TRD Engine Mount Set Ohlins Engine Torque Damper Denso VK20 JAM ECU JAM Exhaust System JAM manifold Camshafts 300 in/ex SARD R2D2 SARD Aluminium radiator SARD Radiator Breather Tank N-TypeD Greddy Oil Catch Tank Trust Oil Cooler Kit No Name Sport Radiator Hoses Samco Silicone Hosing МКПП С160 KAAZ 1,5way AStyle Quick Shift 6м/т 2013 Двигатель: AEM ARP headbolts Ross pistons Scat forget rods ACL вкладыши Castom manifold garrett gt2854r TRD Engine Mount Set Ohlins Engine Torque Damper Denso VK20 SARD R2D2 SARD Aluminium radiator SARD Radiator Breather Tank N-TypeD Greddy Oil Catch Tank Trust Oil Cooler Kit No Name Sport Radiator Hoses Samco Silicone Hosing МКПП С160 KAAZ 1,5way Trd Quick Shift 6м/т 460cc fuel 1JZ-GTE Custom made metal head gasket for 4efte engines. 1.8mm Oil tanc castom Ogura racing Defi давление масла Defi темпиратурка масла Defi темпиратурка воды Defi давление турбины Defi egt Pivot Тахометр+лампа AEM (лямбда) Турботаймер Blitz FATT DC III
  3. 84179558 ]
  4. Good afternoon! share my Projects. a long history of alterations was a lot of Glanza S to Glanza V from 4e-fe -> 4e-fte ct-9 runoff -> 5e-fhe kkk24 -> 5e-fhe ct9/ct12 -> 4e-fte garrett gt2854r Not all photos are preserved, lay what remained
