jim808
    18
About jim808
  • Birthday 01/21/1987
  • Website URL
    http://
    Belfast
    Djing<br />Weekends
jim808's Achievements
  1. Come to think of it i didn't actually grease up the bearing could that be it ????
  2. thanks lads looks like its back to stripin the gearbox once again i'll keep yous posted Much appreciated Jimbob
  3. ok need some help here really starting to lose interest in this car My first gearbox lost 2nd so got another from breakers, my mate fitted this and i noticed a slight noise when sitting still with clutch out ( went away when clutch pushed in). This noise got louder over nxt 2 weeks. I thought it might of been the thrush bearing even though there was a new one fitted so had a bit of an inspection and seen that the box was leaking oil and was nearly dry . So swapped the box for another one and bought another thrush bearing just incase. i fitted the box, filled with oil, turned the key, and still i hear this noise. its not just as loud. Also when driving, when i start to pull away in 1st i sometimes feel through pedal and hear a pretty loud grinding noise. its fine once driving. Can someone help me out I can still only think 'thrush bearing' is there a certain way it has to be fitted???? Thanks Jimbob
  4. The length on mine is about 124 mill and it still the same i can't think what it could be. It was boosting more than that on standard actuator???????
  5. ok the actuator is fitted I've ajusted it about as far as it will go. the part that actuator moves is sitting about 11 o'clock and won't go anyfurther and its still only boosting to 0.4 bar. has anyone else had this problem or can anyone help me out I'v also fitted a greddy bcc Thanks Jimbob
  6. ok i'v got the old actuator off and there is two pipes going into it. on my new actuator there is only one place for a pipe to connect.Is this right and if so which one do i connect and what do i do with the other one Thanks Jimbob
  7. Hi is there a thread to help me fit an actuator Cheers Jamie
  8. can anyone help me out with a wiring diagram for a Gredd BCC cheers Jamie
  9. Can someone tell me what are the biggest discs that will fit behind 15'' wheels cheers Jimbob
  10. Hi just wondering if someone could tell me whats the difference betweem oem and the kouki headlights and does anyone have some to sell cheers Jimbob
  11. Took the rear fog out completely and still no change ,still blowing horn fuse?????? Could it be the horn relay?? Also none of this has the indicators working?? I'm thinking a visit to the autospark could be in order
  12. No problem ill check the earthing over again Sorry about the text chat
  13. Ok my car just failed MOT i was fittin the rear fog the nyt before which isn't a big job i tapped into the dipped beam done the erths and the switch, the fod wrked swt but my indicators, hazard lights and now my horn wont wrk. I checked al fuses my horn one had blew so i replaced it and soon as i put it in it blew again (keeps doin this). i undone wat i did wif the fog but to no effect???? Now i'v no MOT, NO TAX no horn or indicators need to get this sorted can anyone help????
  14. The lexus is my bro's got supra engine in it not quite finished yet have to get few pics up its the weapon Yea its a Blitz
  15. Looks sweeeeeeeeeeeeet mate good job
