TO82
    68
    West Yorkshire
TO82's Achievements
  1. Nice one lads cheers for the help, are those mr2 drop links for the new shape (mr-s)?
  2. Anyone know the dimensions of the stock brackets?
  3. Hi does anyone know if the U brackets that hold the trd to the car are the same as the stock ones? I know the internal diameter of the bushes is bigger, unsure about the external domensions? I have the bushes but have lost the brakets. Also the 90 degree drop links found on some GT/glanza's from the factory and in use with the trd ARB, where's the best place to get these? Are they the same as any other Toyota etc? Any info greatly appreciated!
  4. Cheers Ep82/91 all the same?
  5. As above after a pair to recon an polybush Any help appreciated
  6. http://www.dynoperformance.co.uk/index.html
  7. Dyno performance services ltd Check them out on FB
  8. I'd say both those kits would rattle, I have one here and the flywheel and pressure plate has springs which holds them apart when the clutch is depressed, it looks similar to the left hand one but with the small springs and machining on flywheel and pressure plate to suit. Would you be willing to part with the release bearing?
  9. Item For Sale: exedy paddle friction disc Item Condition & Description: used, well worn one side more worn than other, didn't slip would be ok for someone to get relined maybe? Price: £10 Pictures: Payment & Shipping Details: £5
  10. Item For Sale: lightweight flywheel unknown jdm brand Item Condition & Description: used heavy surface rust, maybe warped? Had this fitted to my car with no issues when I replaced clutch I decided to get it faced, once I had it home I noticed that more material was removed from one side to the other (see pics) someone maybe be able to do somthing with it I'm not sure? Seems a waste to scrap it?? Price: 25 Pictures: Payment & Shipping Details: £10
  11. Item For Sale: CAP 5 PUK unsprung friction disc Item Condition & Description:new, some surface rust from storage, no box. Price: 30 Pictures: Payment & Shipping Details: £5 to uk
  12. Yes and all plastic afaik
  13. I'd take passenger one at the right price?
