raymond
    14
raymond's Achievements
  1. Cheers for the heads up dave200 but the turbo seals were replaced about a year ago and the smoke was really bad when the turbo went, it aint to bad at the moment so thats why i think its the stem seals, cheers for the advice ryan, appreciate it
  2. Hi all, gettin some blue smoke and pretty sure its stem seals, was gonna re build the head, anyone have any opinions on getting the head ported and poloished, does it make much difference??? Also should i stick with standard head gskt or get another, just not sure on depth 0.6, 1.0, 1.2mm The car has s/s mani, de cat, fmic, jam ecu, colder plugs and will be getting hybrid ct9 very soon Thanks for any help/advice Raymond
  3. **** bump ****
  4. i have standard suspension, dont think its the exhaust, noise is like a clunkinig noise so think it is somethin takin alot of wheight like engine mount, top mount???? startin 2 do my head in a little
  5. Thanks alot SiClan, help is very much appreciated, next on the list now is cobra daytonas and universal sub frames. cheers
  6. if you weld starlet legs onto universal frames would the seats not be really high??
  7. Hi all, seem 2 have a knocking noise soming from my glanza, at first it sounded as if it was coming from the back but know it may be the front, seems to knock when going over a bump in a corner, doesnt seem to bad going over bumps on straight bit of road, looked at springs, shockies, drop links, trailin arm bushes, all seem fine. Thought it may be poss engine mount. Any help appreciated
  8. No i have 2.5" turbo to tail exhaust apexi power induction 8.5mm magnecor leads iridium plugs greddy b.c.c H.K.S actuator Did have r.r.f.p.r but i lost all faith with them so standard f.p.r is back on
  9. Hi all, should be gatting an Apexi saf 2 but was hopin someone could tell me how they are to fit and if anyone had a wiring diagram??? Also will a standard fuel pressure reg. and 255 l/h fuel pump and saf 2 be ok for 1 bar of boost??? thanks for any help
  10. Hi all, really really want some cobra bucket seats but think it may be more hastle than its worth, can anyone tell me if there is a subframe that will fot ep91 or if you could put universal subframes in??? thanks for any help
  11. thanks for the welocome everybody, yes enzo that would have been my car, prob pickin the gf up from work, am gonna go out 2night and try and take some arty photos to try and make the car look good , just hope the weather gets better
  12. Think i would be up for that but iam tryin to get a s.a.f at the mo so need to get it set up before rollers and would rather have new exhaust on by that point aswell so could be a maybe?? cheers
  13. Hi peeps, had a problem with my de cat pipe (cracked at welds), i have gotten in touch with a company down south called blue flame, they are taking my car in this fri so they moc up a system, iam gonna tell them bout probs some people have with de cat pipes but was wondering if us would let me know if you wanted a certain style?? I was thinkin bout 4" slash cut tuneable back box but i would like it if it came out at an upswept kinda angle that you see on 200sx or evo. any comments appreciated
  14. Hi everybody, names Raymond, am from Glasgow, am 22, got a 96 glanza v, had it for about a year now, been with the tgtt for a while but didnt seem much help hope you guys will be better also lookin forward to hopefully meetin up with some of us mods on the glanza so far are: w.e.p.r turbo back exhaust apexi power induction h.k.s actuator 8.5 mm magnecor leads iridium plugs greddy b.c.c blitz b.o.v blitz tt
