greendaysimpson
    18
    Aberdeenshire
greendaysimpson's Achievements
  1. Who has any pictures of there FMIC set up without cutting there front bumper?
  2. Yes I know the clutch won’t fit a standard flywheel. I just want to check if another flywheel solves the problem that’s all.
  3. That’s the clutch and flywheel kit. Iam looking more to the flywheel. All surfaces are clean. Think I will try and get a standard flywheel and try that first
  4. Has anyone had any problems with there starter motor not clearing the flywheel. It’s an EP85 with a 4efte engine and orc flywheel and clutch kit. Starter motor number 28100-10040 I bought the car with the conversion already done but they couldn’t get the car going. Found out the wiring loom was a mismatch of 4efe and 4efte loom. So have now fixed that. Turn the car over by hand and half the flywheel teeth will hit the starter but the other half doesn’t. Car won’t start when the starter and flywheel touch just doesn’t mesh. It will however start when flywheel isn’t touching but still hits the starter every half rotation for the brief time I let it run. Took everything off and all looks ok to eye. Tried doing a runout reading off the back of flywheel and if my gauge is correct looks like it has a run out of 3mm. I dont have another flywheel to put on but think it may just be that.
  5. Looking for ep82 doorcards with arm rests
  6. Found the earths at nearside and offside front inner wing next to head lamp had not been tightened. Solved the problem when tightened. Cheers for the help GP82
  7. Every time I use the indicator the fuel pump will buzz for the first click of the indicator left or right. If I use the hazards the fuel pump will pump on and off in rhythm constantly. That’s just with the ignition on. If the car is started it will cut the engine out every time it’s pressed. Any help welcome
  8. Looking for ep82 rolling shell
  9. Does any one know the difference between these wiring looms? Iam looking for a full loom to fit my ep85 and have been offered a mk1 loom but not sure if it will do or not?
  10. Looking for a fully uncut ep82 wiring loom if possible.
  11. 98 spec oem bumper lip front and rear
  12. Looking for glanza parts in red preferably if not doesn't matter interior bonnet bootlid front bumper rear bumper Side skirts
