Pinball
    16
About Pinball
  • Birthday 06/01/1989
  • Website URL
    http://
    Gatwick
Pinball's Achievements
  1. Done nothing like that just made abit of a crunch over first pothole but otherwise no problems to report after that. Ryan
  2. Thanks very much thats guide is rather handy. It should be on in a few weeks just been flat out. Ive fitted the panhold rod but with the spring not under tension and made a right noise when went over first pothole but now its seems alright. Thanks again Ryan
  3. When fitting a adjustable Panhold Rod do i want the springs under compression? Like they would normally be? Also is this the same for fitting an rear Anti roll bar? Thanks Ryan
  4. thanks for thats i will see how we go. easy to install bonnet pins? there a guide anywhere? like with what tools and that plus where to attach them on a starlet ep91? and what make bonnet pins would you recommend? Thanks Ryan
  5. It fits no problem but sits on the latch but doesnt want to lock. Its sits up like when you pull the bonnet pull. If that makes sence. Its a N/a bonnet for sure. Thanks Ryan
  6. Thanks Professional all the way then. looks like im going to have some new tools YAY! Ryan
  7. Its a N/a bonnet for sure. So no adjustment on latch? Thanks Ryan
  8. What do people think about the Halfords Professional Tool range? Anyone got them? any good? as they have a sale on at the moment for the 150 piece set for £100 which i though was pretty good considering snap on make the halfords range? Is this true? Comments please Thanks Ryan
  9. Sorry i wasnt clear ep 91 n/a was an S but dont make a difference. Thanks Ryan
  10. I got myself a new bonnet and im having problem fitting it. It bolts on alright but im having problems getting it to latch. Is there a screw to adjust the latch at all? Any help would be great. Thanks Ryan
  11. Thanks for that Ryan
  12. Was wondering if it would fit. Thanks Ryan
  13. I have no idea. I think it was just a grounding issue on the horn as i rubbed it back with sandpaper and it works fine now.
  14. Im not actully sure i just think it was a grounding issue on the horn as rubbed back with some sandpaper and now it works fine.
  15. All fixed now! Thanks Ryan
