matty1330
    4
matty1330's Achievements
  1. matty1330
    Inlet mani
    Looking for a wepr, zisco or racetech inlet. if nobody is selling one I will go to one of them direct.
  2. thanks mate, 1mm didnt think it would be that thin
  3. as title says, need help quick please
  4. this is for 96 glanza v 15100 PUMP ASSY, OIL15100-11071 4EF*..EP9* 1 $154.3115100-11071 4EFTE..EP91 1 $154.3115100A PIN, RING (FOR OIL PUMP SET)90253-09001 4EF*..EP9* 2 $1.3715100B RING, O (FOR OIL PUMP)90301-62006 4EF*..EP9* 1 $3.3115100C SEAL (FOR OIL PUMP)90029-21020 4EF*..EP9* 1 $6.3215100P PULLEY, OIL PUMP DRIVE SHAFT13524-11020 4EF*..EP9* 1 $21.1215100R SENSOR, CRANK POSITIONNot applicable15101A SEAL (FOR CRANKSHAFT)90311-35035 4EF*..EP9* 1 $9.7390311-35040 4EF*..EP9* 1 $10.3515102 ROTOR SET, OIL PUMP15102-11080 4EF*..EP9* 1 $50.1915104 STRAINER SUB-ASSY, OIL15104-11190 4EFTE..EP91 1 $80.1115104A RING, O (FOR OIL STRAINER)96721-24015 4EF*..EP9* 1 $3.1915310H REGULATOR ASSY, OIL15310-10010 4EF*..EP9* 1 $35.4690105-06011 *** STD. PART $0.7590119-06084 *** STD. PART $1.2990179-09004 *** STD. PART $1.8791511-60622 *** STD. PART $1.2891643-80620 *** STD. PART $1.07 hope this helps mategoogle_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
