davidni
    4
davidni's Achievements
  1. Thanks for your input. Just reposting to update in case anyone knows the problem now. I went to a mechanic and bought a Drive Shaft. I got it fitted and expected that to be it settled. On my way home the car was STILL making a weird noise everytime i was in a low gear revving it. It was okay when I was in fifth above 30mph, no abnormal noise at this point. Upon pulling out of a junction I heard and felt a bang from beneath the car. I pulled the car over to see that the new driveshaft has done the SAME THING! Wouldn't drive anywhere again of course. My father thinks that it is the GearBox Diff because he believes that is the end of the line? Anyone got any ideas? Thanks.
  2. Hello Folks. I have a 97 Starlet Sportif with 40,000 miles. My nearside pass/side drive shaft has popped out of the inner cv or tripod joint, it has tore the rubber boot and the shaft is now hanging down with the three tripod bearing on the end of the shaft still intact. The cv or tripod housing is still connected in to the transmission. Has anyone else had this problem? This car may have been involved in an accident before I got it. Could it be that the force of an accident has caused an issue that I was unaware of? I have also recently been driving in deep snow and icy conditions, could this have caused the problem? Does anyone know how to fix the shaft back in or will I need a mechanic? I have included a diagram to try and show the problem better. Uploaded with ImageShack.us All help is appreciated. Thanks.
  3. Thank you! Do you know where I can locate the head unit connector block? I've been told that on a previous starlet we owned we just disconnected the two front speakers and ran the cable straight to the boot. I'd rather have the front ones included too if thats a good idea? Just need to know the location of the connector block and I can begin Edit: Is it just the speaker cable that I need then also? Is this a simple job?
  4. Hey, Firstly i'd like to thank this forum for helping me with several issues in the past and I apologise if this has already been posted although the search tool didn't find anything alike. I just purchased vibe 6x9s and i'd like to install then in the rear in the parcel shelf(?) Heres a bit of background. My father has been a starlet enthusiast for years and we have 4 currently. My brother has 6x9s installed in his rear parcel shelf although his is an SR model. Apparently the wires were installed already in his as the previous owner may have had speakers already in the rear or thats the way they come as standard? I'd like to install them myself and get some experience. Will there already be wiring in the rear for these speakers? I have the wire available already if not, I'm just not sure exactly what I am doing and if anyone could tell me where to look for things or simply exactly what I have to do to get a wire to the rear to connect to the speakers. Many thanks.
