chriswoodfto
Member-
451 -
About chriswoodfto
- Birthday 05/11/1987
Website URL
http://
harrogate
chriswoodfto's Achievements
Member (4/8)
Ep82 - Stripped Out How Light Can I Go?
chriswoodfto replied to Taggy's topic in Performance & Track Days
u need to try balance were your removing it though as most of the stuff you can take out is rearwards,seats,spare wheel etcetc,i did it in my colt, took literally everything out and it was iffy entering a corner because of lack of weight at the rear. itll throw the balance of the car out and you might be lighter and quicker in a line but you might find it twitchy n worse ina corner, -
im looking at buying a old mini, i had one for my old car, i wondered if this engine would fit, ive looked at the civic kits you can buy for minis, and aslo thort about the metro turbo engine but wel intrested in this one!!!
cheers, i wont be using them again, weve paid 700quid already over this past year so i cant understand how they reckon we still owe em another 700quid.
really pissed off after that call. moving out in 4weeks so rang em to check if they owe me any money etc... because when we moved in they said 'pay 50 a month and thatll be about right' so i said ill pay you 70 quid just to be sure and that way ill get money back rather than have to pay you... just rang them with the reading and they reckon we now OWE THEM 691 quid. i asked how and they said 'well you wernt paying enough in the first place'. fuckin arseholes, if id of used there initial quote wed be even worse off. 691quid meens we were payin almost half what we needed to in monthly instalments, good job i said 70 quid or wed be really fucked. i dont know how theyve got to that though because we havnt even had the heating on for the last 4months, not at all thru day or night and i make sure every plug socket is off when its not in use... there must be no electric running for at least 8-10hours a day and when we are using it its the thing were using and that only, by that i meen just the tv on, and off at the wall straight away when were not watching etc. dont suppose anyone will have any advice for me because they must have cockd sumit up surely?
cool. will have to do a test fit and then giv u some more info in a couple of weeks.
After chatin t guys on celica owners club, it turns out i may havefluked a beter upgrade than the st 185's. The guys confirmed ive st 202 twin piston calipers which were only fited.t the superstrut celica meaning the carrier is extended to 154mm and wont run on a starlet at all. But the carriers ive gt r from rhe single piston st202brakes which have the normal carrier which is 131mm, same as the starlet. The st202 twin pistons could take 180mm disc were the st185 only 160 i think. Will hav t keep u posted t c how it goes when fitting. Need to find a brake disc now!
it was regarding ep91?
will do, the problem is trying to find the pad anti rattle clip im after, because i dont know what the hell ive got i cant make 100% sure.lol . think its the mr2 clip now tho,
i bought the carriers and the piston bit seperate, (long story) so the carriers are def 131mm, and its a twin piston ive got, it all bolts together nicly just wondered if its actually gna work, ive been looking at loads of parts diagrams and the carriers are def looking like mr2 ones. maybe the carriers are from the single piston mr2, would all this work then you reckon?
well after buying all the bits to do my st185 conversion, ive found out ive been had and ive got a set of mr2 twin pistons sat in my boot. not impressed at all. anyone ever tried fitting them? the carrier fixing holes are the same width-130mm so anyone see any problems with them working? chris.
right, ive been trying to finsh my brake conversion and its been a bitch finding the right pad support clip, all the sites ive found that 'used' to have the parts diagrams have been shut down but finally i came accross one that still works, and has all the diagrams. so i thort why doesnt someone put it together on a cd (im too lazy and dont have enough time but id be happy to pay a few quid for a copy) before they get rid of this site too and were left with no option but to use toyota (which in knaresborough are shite) might also be usefull to do the celicas that we sometimes swop parts with, i.e st 185 etc. http://www.megazip.ru/ru/auto/toyota/ just an idea....
hi guys, keep noticing the cars not quite hitting full boost at the mo, it normally boosts to about 0.8-0.84 when foot flat to floor, but its only hitting about 0.77-0.78, just wondering if its got anything to do with the filter on the car. for some reason the filter eliment keeps melting on the outside.theres a few spots maybe a 10p in size, so with the filter having the airflow restricted could this cause the slight loss of power? dont think is a leak as when it hits full boost it holds it without it slipping back down. cheers guys.
sorted guys. chuked two nuts on the bolts i cud get to with no extenshon on the rachet and hey presto back to normal, when i get home tomorow ill sort them all proply. As ever, great help guys, thanks a million
right side at the cat, i got abit caried away i think,lol
its def the cat mate, ill check the oil feed though just to be sure, it was just my shitty description to begin with.
