andieep82
    33
andieep82's Achievements
  1. hi i have just had my head gasket done and now car seems to be smoking white when on idle and just on pull away, doesnt smoke on boost at all and coolant level isnt going down at an alarming rate. i have a fuel pressure reg which i have set to 3.1 bar to run 1.0 bar of boost pressure, i have a cracked mani also at the back just wondering what this could be??? as wasnt doing it before head gasket was changed
  2. cheers mate diamond ima pick one up in the morning then thanks alot
  3. hi i have a 1995 gt turbo and am just wondering if i can get a alternator belt from halfords?? is it the same belt as a n/a starlet?? any advice would be much appretiated thanks alot
  4. hi i have a problem with a ouple of lights come up on my dash board and i cannot find anywere on the internet how to read them if you dont no what they are? does anyone no if there is a link to a page where i can read about all the lights and what they mean??? its the battery light and the one next to it on the left??? thanks
  5. does anyone no what sequence you have to tighten them up in and what side longer ones go and what side shorter ones go i am doing this today really need the help thanks
  6. hi i have blwon my head gasket and am just getting all the parts together at the mo. i asked the guy at the parts department and he said there was 5 bolts, that cant be right im sure it is 10 can anyone please confirm my thoughts even mini engines have 9 head bolts???
  7. hey i am thinking of running bigger injectors as the ones i have now are standard and dieing! i only plan to run jam ecu with blitz hybrid so which size would be best would it be 330cc and if i do change do i have to get it mapped or will the ecu just learn that bigger injectors have been fitted??
  8. could be one of your injectors not running correct fuel cycle
  9. am going to usc tommorow in a convoy from bromley, kent. should be good look out for us black ep82 and white ep82...
  10. any more advice on this one guys n gals??
  11. Ive got a fuel cut defender which is wired in all fine and its definetly not fuel cut, it only happens when i put the fuel pressure up to 3.1 bar, i have now fitted the standard fpr bk on and all is well no hesitation. and the fuel pump is now not whining. it only hesitates when the fuel pump whines???? and sparks dizzy and leada are all brand new
  12. Hi i have just got my car running 1.0 bar on a rrfpr and hks actuator, i set the fpr up to 3.1 bar 45 psi so that i could run safely at this boost pressure. Right so now when i accelerate i get a hesitation like the fuel isnt reaching the engine quikly enough? since i have done this the fuel pump is making a horrible noise ( still the standard pump) am i right in saying i need an uprated fuel pump to run this pressure safely and hence stop the hesitation???
  13. thanks for that mate i ordered non abs as i no my car doesnt have it but i have fitted the brakes now and they are sweet as a nut it doesnt make a difference abs or not on the front but the rears are where you need to make sure you have the correct discs. i have also put them yellow stuff pads on and oh my god they are the best pads i have ever used from cold and even better when roasting hot. in all pretty impressed with the brakes i bought considering the whole kit with pads only came to £260 well chuffed
  14. Are these the same fitment for both ep82 and ep91??
  15. hi just wondering if anybody knows weither there is any difference in the front discs on an abs and non abs ep82???
