michael
    5
About michael
  • Birthday 07/22/1974
    Co. Derry
  • Yahoo
    mmcgarry405
michael's Achievements
  1. Paseo update, found faulty fp relay (using the Starlet 4e-fe wiring diagrams) but car had to be towed to get it started. It still wont idle, but it will keep running whilst there is a bit of throttle held!
  2. After swapping the Ecu with one from a starlet, checking and cleaning all the earths I could find, then checking the signal from the transponder ECU, I put the original ECU back and i now have a MIL lamp. STRANGE!!!! (I was sure the ECU had been spiked) but NO fault codes???????? I then stole the new battery from the wifes celica to eliminate that, but Car is still not starting. Will post any further developments
  3. We changed the engine as the old one had oil starvation issues -(previous owner fitting spurious incorrect one!) Changed all intake and fuel rail components from old engine(it was still going but very noisy) Started engine after refit, it run poorly then after putting the battery on overnight charge the car wouldn't fire at all done all the checks in previous post. I'm stumped as to the problem
  4. First, I have Autodata 3.18 on my laptop for work, which does not have any Pasoe wiring diagrams. I need the wiring diagram for Engine Management, and Immobiliser as my beloved paseo is not sparking! Power going to dizzy; coil, leads & pick up coil all well within resistance levels, tried fitting a full dizzy off a car with only 20K. New Platinum plugs fitted, MIL Lamp NOT working, fuel pump operating
  5. Could anyone get me a wiring diagram for a uk spec 97 model paseo. I've tried haynes, autodata, online, but have got no success.
