deano
    17
deano's Achievements
  1. <BR><BR><BR>The idle screw on the throtle cable pulley, it actualy started playing up again but i got it to steady again so it's somthing to do with this.&nbsp;So i think when i get a minute i will strip it all down clean and adjust cable slack.&nbsp;&nbsp;
  2. The idle screw on the throtle cable pulley, it actualy started playing up again but i got it to steady again so it's somthing to do with this. So i think when i get a minute i will strip it all down clean and adjust cable slack.
  3. Eureekaaaa messed with the idle screw today, it seems that it was wound out that far that it was not doing anything. I wouned it in so that it was idleing at 900 rpm and it sits pretty much bang on so that is where it is staying, Simples :harhar:
  4. deano
    Idle Problems
    Checked with camskill they do have 2 the one i need is £48 + p&p is a few quid short of Toyota. Anywho had a little development today i noticed my lower rad hose is not getting warm it is staying cold so i would think my probs are steming from a stuck thermostat. I will change tommorow and keep you all posted of the outcome. Need it ready for RCSC this weekend or the misses will have me nuts. I haven't even had chence to wash me supra yet kin ell
  5. deano
    Idle Problems
    That makes sense, thanks for the link. The one at camskill is for models up to 97. Mine is a 98 do you think it will be the same because toyota quoted £57
  6. deano
    Idle Problems
    Went in to toyota today and spoke to one of the technisions he said the idle control valve which has been described on hear has more to do with the air con so i tried puling the plug off while the air con was on and low and behold the revs droped. He said they recently had someone in with the same problem and it turned out to be the water temp sensor. I don't realy understand what the water temp sensor has to do with the idle, maybe someone might be able to shed some light ;)
  7. deano
    Idle Problems
    They all seem pretty good but i will go through them again
  8. Cheers bud i relise that now. An icv instead would be handy before i go buy one
  9. deano
    Idle Problems
    cheers relised that when i started looking. It also drops a fair bit when the headlights are turned on as well what a pain in the arse.
  10. deano
    Idle Problems
    I will give it a go tommorow. cheers
  11. Anyone with an ep91 turbo live in or around the hull area need to try an icv off your car before i buy one to make sure this is my problem. would be much appreciated
  12. deano
    Idle Problems
    Where is that located and what does it look like bud this car i bought for the misses i have a supra so just getting to grips with these. cheers
  13. deano
    Idle Problems
    Mine does not pop or bang just fluctuating idle other than that its as sweet as a nut.
  14. Does anyone have any idea as to what causes the tick over needle to fluctuate. I have cleaned the i c v, put new leads, plugs and fuel filter on. The car is a 1998 bog standard 60,000 mile manual turbo ep91. The only thing i have not changed is the dizzy cap and rotor arm which i have just ordered from camskill. When i pull the plug on the i c v there is no change in the idleing does this mean it's nacked because it is starting to do my nut right in
  15. deano
    Icv / Tps
    Hi, can anyone post a pic of the Idle control valve and the Throtle position sensor on the 1998 EP91 Glanza manual turbo. Got slight eratic idle on tick over and cant seem to get any sence out of previous posts. Help would be much appreciated
