ad13
    4
  • Website URL
    http://
ad13's Achievements
  1. Well, I bought a cap and a thermostat and changed the cap straight away since it was easy. Guessing I'm going to need the thermostat, it's still heating up. Next up... where can I get a resistor pack? Anyone know the Toyota part number? Edit: Scratch that, I found the part number. Still, a Google turns up no one? Edit 2: Scratch that again, got one order from my local garage for next Friday.
  2. It's not been losing water or the like, and it starts okay. Thermostat's probably the answer - the radiator cap seems pretty firmly sealed. Where is the thermostat on the Starlet? I can't find an engine diagram for this car for the life of me! Cool, I'll try and source one of these things later. Cheers folks!
  3. Hi there, I'm having a few issues with my 97 Starlet at the moment, I'm unsure whether they're related or not. First off, when I push the car a bit hard (70 on flat, 60 on an incline) the temperature gauge starts to rise. I've checked a few things, namely: - Oil level - Radiator fan (seems to be on quite a lot though) - Air filter My second problem is that my cabin fans only seem to work on the highest setting - the middle settings don't do anything. I'm not sure if these two problems are related. Has anyone seen anything similar? Cheers Andrew
  4. Hi guys, I've had an oil leak for the past few weeks on my EP91 Starlet Sportif and finally got round to looking at it today. It looks as if the sump has corroded right through, when we dried it and ran it it started to get a bit wet again. I find this a bit strange as it appears to be made of steel. Has anyone else come across this? My local scrappy doesn't have any Starlet parts in stock, and he said that even if he did he'd be hazard to take the sump from an engine as he'd rather sell the whole block. Does anyone know the part number for this? Cheers
