Rob Graham
    48
About Rob Graham
  • Birthday 06/06/1991
  • MSN
    yimbug@hotmail.com
    County Durham
Rob Graham's Achievements
  1. Just copy and paste into the url tab?
  2. How do you upload photos on the for sale section? tried linking to photobucket but not working, is there a size limit or something? Any help would be much appreciated, cheers
  3. Yeah they're the same part numbers so would you be able to supply them??
  4. Are glanza boxes c56's? N I'll try n check if they're the same pinion shaft n crown
  5. Is it a glanza box that you've got in bits mate?? I think the shaft will be the same just not sure about the crown wheel, SOS for taking ages to reply
  6. Yeah I know, not exactly common parts either :S
  7. I need a pinion shaft n crown wheel for me LSD box n just wanting to know if anyone knows where to get these parts for a decent price or if direct from Toyota is the only place? Any info would be really appreciated cheers
  8. I changed the gearbox, bought an LSD box from a lad in Washington n he said he got it rebuilt n never got fitted. I fitted box n shorter shaft n took for a spin n it has a knocking noise which speeds up n slows down according to wheel speed. The diff seems to have a lot of play but not sure as I've never really dealt with any LSD's. also when I dropped the gearbox oil back out it was glistening, has anyone had a gearbox rebuilt n the oil been the same, only drove 3 mile before taking back to garage. Just hoping gearbox isn't knackered. It's also had the housing repaired lol but the lad did seem genuine :S. Any ideas would be much appreciated
  9. Yeah mighta been, was busy looking at mods when I shoulda checked the reg lol, looked well like
  10. Red glanza near Inverness, carbon fibre bonnet, jap fogs n 99 spec tail lights is all I had time to spot before nearly going up some bodies arse lol, looked v shiny
  11. How easy are they to fit? Has many people done the conversion??
  12. Just changed standard gearbox for LSD one, funny noise? I've just changed my gearbox for an LSD one, the original one knacked the synchro on 5th n started jumping out. Now I've put the new one in there seems to be a lot of play when spinning the wheels back n forward :S. When I'm slowing down there's a knocking noise. When I bought the box the lad gave as the shorter driveshaft but the other one I'm just using off my last box. Is there any difference in the splines on the non LSD driveshafts to the LSD ones?? Or do you think it's something else?? Proppa head scratcher, just thought I'd put it to the gurus out there
  13. Deffo would be interested in these , when will you have them??
  14. I'm after a 5th gear and syncro set, just wundering if anyone could shed some light on where i can order them from. thanks
