Tobyb
    9
About Tobyb
  • Birthday 08/15/1989
    Oxford
Tobyb's Achievements
  1. can anyone help me??
  2. My neighbough is rebuilding a td04 turbo for me at his work, and he asked me whether the water lines and oil lines need to flow the opposite direction because of the turbo being used the other way up on a subaru, can any one tell me if you have to change the direction pin on them or should he just leave it be? Thanks in advance Toby
  3. Tobyb
    Handbrake cable
    Hello am i right in thinking on my ep82 the handbrake is in two parts one for each wheel? The passenger side wheel is not held in place when the handbrake is on where the drivers side one is, Where is the best place to order one from as got MOT at the end of the month and need to fit one asap Cheers Toby
  4. I have done this with a friend on his subaru, we wired them between the live and the injectors on his, this was to limit the current going into the injectors thus keeping them activated for longer, his car is running fine without problems, but not totally sure if this would be the same, id imagine so.
  5. Mines held in with one screw and some double sided tape at the bottom by the dash holds fine
  6. Hello sorry havnt uploaded them yet, took me a while to get around to it. So hopefully they are below
  7. that sounds a whole lot better, thanks alot Toby
  8. Hello Guys, I recently bought my ep82 gt turbo, and when i bought it it was obvious that the guy before me was planning to do alot to the car, as have got reciepts for hks fuel pump and fuel pressure regulater etc aswell as alot of other engine mods, which arnt all fitted. The problem showing is the fuel pressure is at 4 bar at the moment, which is very high, the question im asking is does anyone know what the standard fuel pressure should be running at so can set this up correctly? Cheers, Toby
  9. Hey guys My name is Toby, i bought an EP82 Starlet GT Turbo mk3 last night, and its my first starlet. Just a couple of questions, obviously i would like to give the car a service at the weekend, is there any specific oil you would recomend using? Also with the car i got a HKS f-con ecu, where could i sell this as i am looking at getting an apexi ecu, along with the hks ecu i have an fcd. Cheers Toby
