matt-xliturbo
    7
matt-xliturbo's Achievements
  1. looking good mate hope not too many problems occur.
  2. got a couple pics of the completed car here. will add some of the the project being undertaken soon. http://s1197.photobucket.com/albums/aa440/koiavery88/
  3. The loom was the hardest bit but not really that bad mate. I swapped the entire loom from the car including interior light and door switches. Just made it all work as it should with no wiring issues. Maybe slightly different for you as I used a glanza but I had to do a bit of wiring and swapping blocks about as the rear lights are different not hard really though. Fuel pump was easy although the main feed from it was stuck solid on both cars so a lot of wd-40 was used. The dash came out real easy and new loom sat in with a few cabe ties. I have swapped all the front shafts and hubs and struts over all fitted straight on except my tracking went out a long way with the glanza hubs. I have got the rear hubs off just being painted black ready to bolt on so hopefully a disc conversion on it seems to fit but will need to swap the handbrake cables too due to drum and discs having different connectors. The fmic was a day job with chopping the bumper out. Also a lot of the earthing mounts were in different places again you may not have that problem, but even one not connected was playing havoc with everthing lol. Good luck with it mate ill get a couple pics up of mine soon
  4. Hey there. Just spent two weeks doing this coversion into my xli starlet. I swapped everything full loom inside and engine. Shafts and hubs with the gear box. And a fmic which was hard to fit in the standard bumper lol. There was a few little bits that were a pain with the swap not much though. I used the other fuel pump it took 20 mins to swap straight over. Only difference is I used all the glanza engine and loom and clocks which was interesting to fit in the dashboard. Would love to be able to help in anyway I can.
  5. Hi just finished my starlet project would be good to meet some people in Plymouth with all starlets. Also I'm getting rid of my glanza shell still has some bit of use on it if anyone needs some parts .
  6. Cheers guys and girls will sort some pictures real soon. Just got to take them. Can anyone advise where on here to post to see if anyone near where I live needs any bits from my broken glanza or old na engine. Cheers much appreciated.
  7. Spent the last 2 weeks putting my glanza engine into an old xli starlet. I think the engine is not far of standard just need to figure out how to give it more power now. Any advice would be very welcome, it currently has air filter, full kakimoto exhaust, hks fuel cut thing on ecu and the low button has been bypassed. I'm down in Plymouth are there many other people down this way into these starlets?
