Qwerty123Il
    9
Qwerty123Il's Achievements
  1. A new standard one?
  2. Ok, I thought that would be the case! Thanks
  3. Hi, I'm in need of replacing my exhaust manifold to head,!gasket. I was told I'd be better off with a upgraded one, but all I've ever found are oem or Toyota original (which I thought was the same thing!?) no upgraded or performance ones at all. So is there such a thing, what benefits would it give, and where do I find one!? Thanks
  4. Ok I'll ask for a fast road set up and hopefully he will do it right!
  5. Yeah the place I will be going to has the new(ish) 4 wheel laser alignment system. So by a slight camber and right toe set up, could you give some numbers! I'd rather be able to say exactly what to do rather than hope the guy doing it does it right!
  6. Hi, I'm in need of some tyres which I intend to get fitted tomorrow, and I will get the tracking sorted. I also want to sort the alignment out on all the wheels in terms of camber & toe etc as when I had the coilovers fitted I didn't have any set figures to use and as a result I can't remember what it's set to! (the tyres are the same ones that were on before and are not worn or anything as a result of dodgy setups though!) Basically I want the figures for normal everyday road use, with some more sporty shall we say driving thrown in as well. My daily drive is an a road to work nice and easy and then a b road home, where traffic dependent I have a bit more fun ;) (yes I go a different way to and from work!) I won't be using it on the track so it's simply a sporty everyday set up, keeping the tyre life decent etc. I know there is a few threads about this, but I wanted some personal advice for my needs! Many thanks in advance people!
  7. I don't want to buy an emu really, as I want to go standalone at the end of 2012 so it would be a waste. My mods are, blitz exhaust, decat, hks mushroom filter, FMIC and a SSQV. It's running at .6bar at the moment as my garage said the manifold is not in great nic. I'm getting a new stainless one in January and after that I will go to 1 bar. I've heard I need the Fpr although my garage didn't mention it! Where is the best place to get the jam FCC and SARD Fpr?
  8. Qwerty123Il
    FCD
    Hi everyone! This is my first post! Hi, My car is hitting fuel cut far to often, so I need a FCD! I've been looking around, and the main two I've found are : Greddy BCC HKS FCD But from what I've read the hks isn't great. What's your experience with it? The Greddy is better from what I read. The other is the Thor FCD, this seems to be the best, but all the posts about it are from supra owners so would it work!? Thanks
  9. Top seller, as described many thanks.
