Grazza
    11
About Grazza
  • Birthday 06/08/1990
    Essex
Grazza's Achievements
  1. rsr t2000 lowering springs, lowers the car by 25mm
  2. ok thanks for the heads up mate
  3. ok thanks, how much did they charge?
  4. need my gear box checking out n maby a second gear sincro fitted as when im changing up from 1st or changing down from 3rd at speed its stuborn and sometimes wont go into gear?, the box is also quite stiff going into some gears??. Any advice would b apreciated fellas.
  5. thanks fellas im lucky enough to have factory lsd on my glanza and im taking my motor into work 2moz to get it up on a ramp n have a good route about the suspension and stearing as its feeling a lil roapy ;-s, ive got bc coilovers on their so might give them a going over aswell to check their all good as their only couple years old.
  6. Hello fellas Currently got bc coilovers, and adjustable panhard rod on my 1999 glanza but as u all know the handling on the glanza isnt all that so was going to do a couple more worth while chassis mods: wishbone front poly bushes wishbone rear poly bushes or anti lift/caster kit ( if its worth the extra cash) either polly bush front arb and new drop links of whiteline arb kit ( if its worth the extra cash) rear beam poly bushes ( if their worth changing?) whitline rear arb kit then i need a good garage to set up my chassis after i fit it all, somone who knoes how to set the toe/camber/alignment properly for fast road but comfortable driving, preferably in the essex area.
  7. Think im going forged now fellas as i dont wana do half a job n risk it fucking up. Apreciate the help though Thanks
  8. Hi guys need some engine re build parts for my 1999 Toyota Glanza V as I made school boy error of replacing the water and vacum lines on my throttle body the wrong way round and seize my pistons up, minimal damage just 2 bent conrods. Parts needed: - 4 conrods (preferably starlet gt as they are stronger then the glanza ones) - shells for conrods or big end shells (standard size) - set of piston rings - full engine gasget set - head bolts - water pump - cambelt kit pm me or call me on 07745306730 Thanks Graham
  9. Item Condition: new/ second hand Price and price conditions:£10101 Extra Info: Need a HDI/HDI replica intercooler pipe as had to re do all my intercoooler piping. The pipe i need is the pipe that goes from the inletmanifold down to around mid way in the engine bay and it is very important that it has the conector pipe for a dump valve welded on it aswell. Or if anyone knows where i can get one new from let me know and im not fabricating one up because thats partly the reasone i need one haha!. Pictures: Contact Details: reply or pm me Location:Essex
  10. Need a HDI/HDI replica interccoler pipe as had to re do all my intercoooler piping. The pipe i need is the pipe that goes from the inletmanifold down to around mid way in the engine bay and it is very important that it has the conector for a dump valve welded on it aswell. Or if anyone knows where i can get one new from let me know and im not fabricating one up because thats partly the reasone i need one haha!.
