Panda.gt
    46
About Panda.gt
  • Birthday 02/20/1994
    Dartford.
Panda.gt's Achievements
  1. Bump upppp Need this thing movingggggg
  2. Bumppppp Will take offers really need gone
  3. No sorry mate cars going as it is And yes it is Jordan tolleys old gt mate
  4. I did plan too but never got round to it mate
  5. Year:1994 Model: ep82 gt turbo Tax: 4 months MOT: 4 months Mileage: Shell 193,000 KM engine Aprox 50,000KM Location: Dartford Kent. Description; Toyota starlet gt turbo, will be very sad to see go but need a change and a bigger car. Running 1.2 bar on toyo hyrid CT9. Engine is fully forged so all you really need is a turbo kit and emanage and your laughing, already has an LSD so putting power down wont be such a struggle. I built this car for my mate who also is on here Jordan.JT and when he was selling it i brought it off him, ive had a starlet before and missed it so much i brought another one. Ive really put some hours into this car seen as the first time i worked on it, it was standard to what it is now i will be sad to see it go. Spec as follows Engine Magnacore HT leads blue, brand new with sparkplugs ARP Headbolts 75mm Wiseco low comp pistons 75mm Wiseco piston rings Wiseco rod's Athena 1.4mm MLS head gasket toyo hybrid ct9 turbo mild steel manifold and downpipe air filter relocation kit j performance fmic rsr exhaust custom catch can + lines hks ssqv bov . (Real none of this fake poo flying about receipt to prove) triple core rad + fan Chassis Cusco LSD Oem front strut brace Oem rear strut brace engine/gear box poly mounts Meister r coil overs Rota slipstreams parada spec 2’s all round pretty much new Electronics Blitz access ecu Depo oil temp and pressure gauges Gizmo boost controller Interior cobra Daytona seats mlr deep dish style steering wheel indigo dials stripped Brakes EBC green stuff pads front Groved discs front Pictures: Price: £4000 OVNO Contact: Any questions and more pictures Call or text me on 07540226026 Thanks Jordan
  6. 2000 without doors and boot? Sounds like a good deal to me ers
  7. 2000 and ill come up tonight Alright mate thanks alot
  8. need intercooler pipe coming out from turbo , short route one please Kinda urgent Thankksss boys
  9. Panda.gt
    idle problem
    yea ive checked vacuum leaks, ive removed everything for the ac all the vacuum pipes off the manifold that were used my the ac are blocked off, its only just started happening and i put the engine in it last year for my mate JT tolley and it was fine no problems atall its only `started hapening last month last 2 months thanks for your reply apreciated
  10. Panda.gt
    idle problem
    ive read many many posts about how to cure idle problems. once ive been for a drive ill park my car on ym drive for just over half hour i come back my oil temp is always between 50 degrees and 80 degrees when it happens, it idles around 500 or 600 rpm and sometimes cuts out and dies. once driven again its fine. adjusted my idle screw but all that done was make my car idle at like 2000 rpm when its not idling rough. ive removed my icv cleaned that out was full of crap ect. new plugs new magnacore leads oil filter change checked timing (slightly advanced) new air filter oil catch can and lines cleaned right out done compression checks and cylinder leakage all ok only fault ive found is when i rest my finger on the throttle pos sensor the idle rises and then gos back to idling rough again really really confused as im a nearly qualified motor vehicle tech Cheers guys
  11. if youve got the patience go to a breakers find a bmw that has the battery in the boot and rip it out! takes a while but it is posible
  12. A lot better than a Sedona haha
  13. If there is already a topic on this can someone point me in the right way but if not. How soft or hard are people running the Meister r's? Had mine on my last gt perfect but can't get these ones the same. A little help will be much appreciated Thanksss
  14. Thanks Jamie and guys! Just ordered some and hopefully put the box in next weekend!
  15. So I glad to say I've brought myself another ep82 not stop smiling since I picked it up. I've had a Cusco LSD in a box in my garage for about a year that I never got to put in my previous ep, now I want to put it in my new one but can't find anywhere trust worthy of getting oil and the correct oil can anyone help? Thanks!!
