Noel Kelleher
    13
About Noel Kelleher
  • Birthday 11/24/1983
    Cork Ireland
Noel Kelleher's Achievements
  1. Are the suspension strut size different to a stock ep82? I see people on here say good things about an "meister r?" coil over that fits them. Any views on how much windup these have, wat price they are? And wud they suit my needs or not? Thanks...
  2. Sounds good Shorty, it's not like it wud have bad traction or anything. I'm hoping the fact that the car will have a good suspension setup that it won't have huge amounts of body roll which can cause an inside wheel to spin up when cornering
  3. I can agree with you there Starlet SR but im a big fan of the starlets, always was and this build mite not work out the best, or cud end up being quite a good little car but I have to try...!! I've built other rallycars before, fwd's, but such a small car with nice turbo power and decent 4wd traction has to be something good. As for parts go, I have seen the odd 5dr ep85 manual for sale in Ireland over the past year, old people and farmers having them and selling off cheap, some not roadworthy and I'm sure more are out there. I think if I was lucky enough I wud come across one and have all the spares I wud need then. Fair point though, it's just the 323 and the gti-r have been done before, and this just has not, worth a try.. :-)
  4. Hi Enzo, thanks for the input. I will prob wait and hope that an EP85 will pop up on this site for sale maybe around the 2.5k mark. Id prob pay more if the 4e transplant was already done. So if you know of one at any stage please let me know..:-) The standard ratios on the ep85 are said to be shorter than a normal ep82 for snow/ice purposes, is this true? Any idea wat speed it wud do in each gear as standard? Its def worth trying this car with the standard 4wd system offroad and then take it from there, they have to grip if you put enough power through the wheels you would think.
  5. Its only a flight away, Be it long I might ad though>>>! ;-)
  6. Wow, alot of info and ideas there in that post. K24 seems to suit more than the td04 for my needs, although the kit that weeJohn gives the link to in an earlier post here sounds perfect for track/rally. On the loose if you are sliding you really cant have much lag if any at all..
  7. Sounds easy but im sure its not..!! The beauty of keeping runnung gear in the ep85 standard is ease of build. Is it a crazy big job to do a celica conversion??
  8. That turbo sounds perfect, minimise the lag is the most important thing. With it I might not need anti-lag. 4yrs is a while to be looking so i will take your word for it..! I see you have serious power going thru your 4wd system. How do you find traction in wet conditions or gravel terrain? Wud it be inclined to spin up one or two wheels?? Good info weeJohn, cheers
  9. Can u give me a brief description between a td04 and the k24 SiCaln? Also do torque figures increase much by fitting these turbos?
  10. Good point though morgey, that's why I had asked earlier about anti-lag, and if it was ever fitted. It wud be a hues advantage on a rallycar but cost and wear on turbos, I'm just not sure. So any info on it is appreciated.
  11. Thanks for the info, ya Im hoping to pick one up in the uk or ireland so fingers crossed, even if the right one cropped up before my build id def look into it, all the way from here..!! That is cheap power really. Id like to think that I would spend around 3g on the engine so I should easily get good power so for that money. With the ratios and diffs, Im guessing I would have to test the car as is on gravel and see how it wud perform. I was reading a post on here about a guy maybe getting LSD's made up for them so just seeing if anyone knows about it A coilover is a must really for winding it up for the rough roads. I run proflex 3way suspension on my civic rallycar which is adjustable in high and low speed dampning and rebound. Its a hard one to call, hoping someone may know something that would fit in there and work good.. So thanks StuDoc72
  12. Hey guys, Im new to this site. Ive recently thought about building a rallycar out of an EP85 Starlet, I dont yet own an EP85 but since seeing and reading all of your info about these cars I think they would make a brilliant gravel rallycar. My plan is months away but this is what Id like to build, I have previously built 2 rallycars in Ireland and am a panel beater by trade. I am fairly mechanically minded and would like to think that I cud make this possible. I would appreciate all of your info, insight and ideas, good or bad. The plan wud be to start with a base 3dr EP85-where is the best plae to pick one up? Wat lind of money does a decent one go for? To fit a cynos engine, 5efe and fit a 4efe head and turbo/ancillaries, hoping that I wud get 200-250bhp, reliable power? How much wud this kind of power cost? Probably keep the gearbox ratios as is, maybe change final drives? The biggest thing is getting a front and rear LSD, which i would need really. Is it possible to get ones for the EP85? There are loads of relatively easy brake upgrades out there, but I would like to see what people think of what suspension I should best use? The last question I have is Anti-lag?? Has anyone ever ran it on the turbo engines? There is alot of material and questions in this thread and so I hope people give all their opinions as the more the better for me really..! It will be next year before I wud start this build but Im just seeing my options now, and trying to get all the info and downfalls now, rather than later.. Big thanks in advance people Noel from Oz (build wud be happening in Ireland..!)
  13. Hey everyone, my name is Noel. I live in Sydney Australia, originally from Cork in Ireland. Came over here a few years back to make a few dollars as work was quiet in Ireland. Heading home for good next year (May 2012) back to Ireland. Im a big Toyota fan, since I first started to drive at the age of 17, I have owned... 92 Corolla 3dr xli 98 Toyota Cynos 89 ep70 starlet 88 ep70 starlet 86 ep70 starlet 94 ep82 starlet soleil s 88 Corolla 1.5 saloon import 92 Toyota MR2 gti 93 Celica Gt 93 Corolla 4dr xli Prob alot more but that is most of the Toyotas Ive owned...! I am big into Rallying and I built my first rally car when I was 20yrs old, it was a 1991 Corolla ae92 fwd GTI, it is still going in Ireland, does the odd rally! Standard car really back in those days. I also like hondas and have had many of them too. My current rally car(that sits in my shed in Ireland) is a civic eg6 with a pretty big spec, its a tarmac spec rallycar... Bear with me on this, I am getting somewhere...!!! Its really since I saw this website it got me thinking about building a gravel spec ep85 rallycar with a turbo engine. So this is what is in my head at the moment, for the future, and I hope everyone here can help me along the way, as I will have loads of questions..!! After all the cars Ive owned, I loved the starlets with there playful handling and nippy power, in any power range they were great fun So hello all and look forward to hearing from you all... Cheers
