Tommyk
    255
    Boston
Tommyk's Achievements
Member (4/8)
  1. Ok mate Il try that
  2. Yh it's bleed up fine and it's had 3 different water pumps obv with the 3 engines so not tht. I wondered if a bad map could cause this and unless it's a faulty rad
  3. Yea kicks in fine mate and on idle and normal driving it fine and even fine when just blit it about it a when I give it some hammering throught the gears up to speed it happens
  4. Hi guys basically since my car was mapped at td and had a new triple core half rad I've had heating issues. It's not down to the engine as this is the third engine it's happened on now. Basically if I give it some thrashing temp gauge goes rite up and heaters go cold and then heaters come warm again and it goes back down. Also spits water out the cap or somewhere but I've put a new high pressure cap on and all bleed up perfect but still no difference any ideas?
  5. Hi guys basically since my car was mapped at td and had a new triple core half rad I've had heating issues. It's not down to the engine as this is the third engine it's happened on now. Basically if I give it some thrashing temp gauge goes rite up and heaters go cold and then heaters come warm again and it goes back down. Also spits water out the cap or somewhere but I've put a new high pressure cap on and all bleed up perfect but still no difference any ideas?
  6. Tommyk
    forged 5e
    Inboxed you
  7. I had same problem mate and I had left a earth loose on my inlet mani haha. Did it all the time tho not just in day time but sounds like a earth to me mate apart from only does it in day time
  8. Hi guys am I rite in saying that the e manage ultimate has anti lag and launch control built in?
  9. Tommyk
    forged 5e
    As above wanting a forged 5e with no issues. Let me know what you got
  10. Tommyk
    5e parts wanted
    Wanted 5e as can run bigger turbo but with same lag I'd have from a 4e so more power more torque and same lag
  11. Tommyk
    5e parts wanted
    Ahh won't matter which I get then mate as will be putting forged rods and pistons in
  12. Tommyk
    5e parts wanted
    Do I want 5efte forge rods then or are they just 5efe? Thanks for help guys
  13. Tommyk
    5e parts wanted
    Ok mate cheers
  14. Tommyk
    5e parts wanted
    320752516672 according to this on eBay I can use my origional scat rods from 4efte to build my 5e ?
  15. Tommyk
    5e parts wanted
    Ahh ok mate thanks for that take it I do need clutch too
