starletezy Posted April 2, 2016 Posted April 2, 2016 So basically my head gasket went on my gt got the head skimmed block looked fine got an Athena 1.2mm MLS Headgasket with ARP Head bolts my mechanic fitted the head gasket torqued down the head bolts down to the right specifications given by ARP started up fine ran perfect no problems noticed the day after when I drove it the left corner of the head was seeping oil out of the gasket cleaned it up droved it didn't seem to leak any further a week later took it for a steady drive lost compression on cylinder 2 and 3 showing 0 psi on compression test could it be that the head gasket some how has failed between cylinder 2 and 3? Cheers Tez Quote
