SplitfireIV Posted April 15, 2016 Posted April 15, 2016 Hi guys,Just wondering what the pinout on my ep91 tps is. Getting conflicting findings on it. As it stands the three wires that lead to the plug are: yellow with red tracer, brown with white tracer and light green with red tracer. Would I be correct in assuming that the Yellow with red tracer is the throttle closed sensor, the brown with white tracer the ground and light green with red tracer is the variable posistion sensor. How does that sound?Hoping to swap over the wires to a Keihin tps attached to a set of bike carbs. Also, what voltage is the toyota tps?Cheers. Quote
