So whenever I start my car the starter makes a big weeping sound (hard to describe) only happens for a second but it's very annoying at this stage now. Anyone come across this before ?
I've had this before its just as the car starts and you let go of the key to stop cranking right? Like I fast metal on metal rubbing sound? Found out it was my starting just touching the plate between the engine a gear box as the starter gear come back in. I just took the started out and went at the area with a file for about 10 mins and it's never done it since. Hope this helps.
Sent from my iPhone using Tapatalk
Yes exactly that man. So I prob didn't line the plate up right after changing the seal. Makes sense cheers man I'll give that ago tomorrow. Thanks
Yeah that's what I had done. And I couldn't be bothered to take the box back off. And it never had the locating dowels in the box or block So it was more of a guess haha
  • 2 weeks later...
Got this done today finally 😀 Great having a car that doesn't squeal when you start it😊
Thanks for the tip man 👍🏻
