Neo95 Posted May 29, 2016 Posted May 29, 2016 Morning, have a spec 6puk clutch system fitted are 300bhp and it keeps going thought release bearin any advice out there?Thanks in advance! Quote
gazza g Posted May 29, 2016 Posted May 29, 2016 i think i have had about 4 release bearings in mine, what manufacturer are you using? i had to bite the bullet and put a blueprint one in that cost over £50 and thats lasted a while up to yet. could also be play in the output shaft that's causing the issue? Quote
Neo95 Posted May 29, 2016 Author Posted May 29, 2016 i think i have had about 4 release bearings in mine, what manufacturer are you using? i had to bite the bullet and put a blueprint one in that cost over £50 and thats lasted a while up to yet. could also be play in the output shaft that's causing the issue?How long has yours lasted i did bout 80mile on the one thats just gone but to be honest i didnt check for shaft play. Quote
gazza g Posted May 30, 2016 Posted May 30, 2016 was around about 100 mile i think before it started wining again, then a few thousand later it was getting a little brave not to change it. never had issues with standard clutches, it must be the extra force required on the pressure plate to open that fucks it up. Quote
Neo95 Posted May 30, 2016 Author Posted May 30, 2016 Still quiet bad for an uprated clutch to not work with a realese bearing ent it. was around about 100 mile i think before it started wining again, then a few thousand later it was getting a little brave not to change it. never had issues with standard clutches, it must be the extra force required on the pressure plate to open that fucks it up. Quote
