THEDANE Posted March 13, 2017 Posted March 13, 2017 Just bought a Starlet from 1997 and would love a rev-counter. Is it possible to connect an aftermarket one to the some part of the engine? Quote
westie Posted March 13, 2017 Posted March 13, 2017 Easy enough to pick up a set of dials from an SR or CD spec car and swap them in instead. There's an easy to follow guide on here. Quote
Linear Posted March 16, 2017 Posted March 16, 2017 If you can't find those clocks, it's worth looking out for Paseo dials too as they'll also fit. You will, however, not be able to swap over the tachometer as you can with clocks out of the SR or CD. If those still aren't an option, you can pick up aftermarket tachometers pretty cheaply that wire up to your ignition system. I'd imagine the hardest thing with those would be running the wiring through the firewall into the interior, but there are plenty of places that could be done. Can't offer much advice on the second option as I went for the first! Quote
