Hello
I'm new to all this so don't know if I'm posting in the right thing.
I have a starlet cd, 4efe engine. The car was sitting in my garage for about a year, I have just got it on the road a few days ago everything is fine apart from idling, on a cold start the goes down to 900rpm then up to 1200rpm when the engine gets warm it will idle at 1300rpm, has anyone get any idea what could be the problem.
Thank you
Jamie
Hello
Thank you
Jamie
ore than likely a vaccume pipe leak(split in one of the pipes) check around the inlet manifold area to begin with
