I have recently got a fmic, and i have a hks bov to attach to the pipework, would anybody like to give a brief explination on how to mount this on, would i need any fitting kits or modifications done ?
its pretty striaght forward il try to explain, take your standard ricirculating bov off and block it off,
is there a fitting kit with your new bov, if so there should be a pipe with two jubeli clips
attach the pipe to the bov and the other end to the pipe pictured above,,
there should also be some thin hose that goes from the bov to the inlet manifold, basicay replacing the thin pipe that went from the standard ricirculating bov to the inlet manifold.
does that help at all?
