hopalong_neil Posted May 29, 2017 Posted May 29, 2017 So I've got an aftermarket manifold and throttle body fitted but I'm having trouble setting up the tps as there is slight play as the spigot is slightly smaller than standard.Given I'm running an emanage ultimate, would it be possible to remove the tps and map out any fuelling problems?The car idles fine but revs hunt when holding it at 2k and the car gets a bit jerky when coasting down sometimes at zero throttle which I think are all related to the tps adjustment. Quote
