Idrees Posted April 12, 2008 Posted April 12, 2008 I found that my 'DOME' fuse (under the bonnet) was fused so I tried a new one, but it blew straight away.I've tried to fit a new one several times but as soon as the fuse touches where it is supposed to fit it makes a spark and a fizzing sound. Basically the fuse is getting fried within a second of fitting it.What could be the problem? Quote
Starletraje Posted April 12, 2008 Posted April 12, 2008 Shorting out somewhere in the circuit, or wrong sized wire could cause it. Quote
Starletraje Posted April 12, 2008 Posted April 12, 2008 NP. whole host of things can cause a problem like this. and i noticed that yours doesn't exactly have a good electrical reputation. Quote
Idrees Posted April 13, 2008 Author Posted April 13, 2008 I tried both ways. With the battery disconnected and while it was disconnected too.When I did all the wiring it was obviously disconnected (well most of the time!)I've checked and there is no short circuit to be found and all the wiring used is correct which is from another Starlet. Quote
