GAUGING INTEREST
HAS BOTTOM END FAILURE WILL NEED NEW MAIN AND BIG END BEARING SHELLS- new oil pump ect. LOCATED SCOTLAND
Servicing:
castrol edge 5w30 fully synthetic engine oil
crossland oil filter
Valvoline maxlife 50/50 coolant
fuchs titan race fully syn 75w-90 gearbox oil
Gold Plug magnetic oil sump plug    ( Supplied by opie oils)
BOSCH 022 45ah Battery
Engine
⦁    Standard 4E-FTE Engine + stock ECU ( BOTTOM END NEEDS NEW MAIN AND BIG END BEARING SHELLS )
⦁    stock PCV delete - Racespec AN-8 rocker cover / Braided lines supplied by RW Devlopments
⦁    ID workz New OE sparkplug tube seals / rocker cover gasket / rocker stud washers
⦁    ID WORKZ Nomex oil return hose
⦁    New toyota OEM Exhaust mani gasket
⦁    New toyota OEM Exhaust mani nuts
⦁    HDI FMIC pipes powdercoated / blanked BOV / ASH hotpipes
⦁    New SAMCO boost pipe joiners and s/s clamps
⦁    HDI FMIC chemically cleaned and VHT painted
⦁    New genuine toyota inlet manifold gasket
⦁    inlet manifold acid dipped inside immaculate and powdercoated exterior
⦁    EVAP Delete - vent to atmosphere
⦁    TD half size radiator + slim fan
⦁    Roose motorsport top and bottom radiator hoses + Auxillary
⦁    Roose motorsport Powersteering lines ( New P/S fluid added )
⦁    Assorted brackets powdercoated
Ignition
Magnacore HT leads + king lead to ig/ coil
NGK iridium spark plugs grade 7 brand new
FUELLING
⦁    3SGE BEAMS BLACK-TOP 340CC INJECTORS
⦁    Powdercoated fuel rail
⦁    New fuel filter supplied by Tuning developments
⦁    SARD RR Fuel Pressure Regulator
⦁    255LPH walbro FUEL PUMP
Wheels -Brakes- Suspension
MeisterR adustable coilovers
Whiteline adjustable rear panhard rod
Standard calipers and discs -Calipers painted
Driftworks steel wheel nuts
ROTA GRID 16" wheels with Rays stickers
4 New TOYO T1R PROXES 195/45/ R16
optional rear strut brace powdercoated and plastics painted
* SILLS , REAR AXLE , FUEL TANK AND WHEEL WELLS STRIPPED TO METAL AND TREATED TO RUST CONVERTER / THEN ANTI RUST CHASSIS COATED IN WHITE *
Its too nice a car to break
looking for £1300 ONO  if you bring own wheels - £1800 ONO with wheels / can whatsapp videos
no bonnet or front bumper / bottoms pics how it sits before i get it rolling shell ready for serious buyer !!
location near Glasgow
Edited by #TIDGEY
  • 3 months later...
