Just changed my thermostat and whilst putting it back on the 1 bolt broke, 1's on and 1's broke, there's no water leaking out of it so should it be alright, theres not much movement in it aswell?? thanks
i did the same the first time i changed it, if you can get some mole grips you could take the thred out??
it doesnt move no water leaks out of it u recon it will be ok as it is?
