DannyMoville90 Posted April 4, 2020 Posted April 4, 2020 Hi, I have recently installed the CD dials to the Sportif. I changed a few wires around as per a guide on here. All lights showing in the correct places and rev counter working. However, when I put on full beams and drive somewhat harder, 30 - 40mph, the fog light and indicator lights illuminate dimly. When I indicate on full beams, both indicator lights come on as well as the fog light. This issue only happens on full beam, dips are fine. Any ideas what it could be that's causing this? Maybe a loose or crossed wire maybe? Thanks Quote
Pinkygti Posted April 4, 2020 Posted April 4, 2020 Sounds like a wire out of place, I would go through them again and make sure. on mine I would indicate and the fog like would flash too, ended up making another earth also Quote
DannyMoville90 Posted April 4, 2020 Author Posted April 4, 2020 OK thanks. Il check the wiring again. Quote
DannyMoville90 Posted April 5, 2020 Author Posted April 5, 2020 There was a brown and white wire that wasn't pushed fully in on the smallest plug in the middle of the clock. I fixed that and it has fixed the problem. Thanks Quote
