246GlanzaV Posted May 11, 2020 Posted May 11, 2020 (edited) Good day all... in need of some help. I currently have 1991 ep82 Soleil which I'm converting to look like a gt (bumpers, lights , wing,body kit etc). I've yet to get a 4efte engine and loom as it is hard to find where I'm from but I did manage to get a 4efte dash loom and cluster. The problem I'm having is that I'm not getting any ignition or lights after fitting the gt dash loom and cluster hence the car is not starting. I've been trying to find 4efe wiring diagrams to compare to the gt to see where I'm going wrong but have yet to make any progress. Any help would be a life saver. Key notes: original chassis is a Soleil 1991 (carb model) Converted to efi (botched job by previous owner). So it's running 94/93 efi fuel pump setup/loom in the rear. Fuse box loom also efi but from the 4door model with the small fog lights Dash loom and cluster are gt mk 2 I believe Engine loom is 4efe internal coil (4-pin & 2-pin) Edited May 11, 2020 by 246GlanzaV To add missing information Quote
