*** Now Added - Toy Tuning Air Filter Relocation Kits (includes filter) - Now Added ***
Hi all,
We've just added our Toy Tuning relocation kits onto the site:
http://www.toytuning.com/onlineshop/intake...sincludesfilter
"Toy Tuning air filter relocation kits are ideal for those looking for a cost effective and hassle free solution to relocate a filter directly off the CT9 turbo into the front bumper/grill. Placing a filter here will guarantee ample cold air reducing inlet temps and increasing bhp. The colder the air the faster they go! Each kit includes:
Induction Kit/Air Filter
Stainless Steel Pipe
Silicone Hose
3 x Jubilee Hoses
Supplied with everything needed to run including induction kit/filter! Each filter is rated to 250bhp@ fly max so more than enough for the CT9. Considering a JDM induction kit alone is more than these kits put together these offer great value for money and a hassle free solution. These kits are also ideal for our Toy Tuning hybrid CT9 units, direct fit and will release a huge amount of potential for the turbos.
The stock inlet track on the Starlets (EFI Pipe) is very restrictive, fine for what the car was designed for but not when looking to increase performance past stock levels. Not only is the stock inlet track restrictive it also runs directly across the exhaust manifold meaning it suffers very badly from heat soak, making the air extremely hot and hampering performance. With these kits you can literally remove the complete inlet track up to turbo and replace with our kit aiding performance, inlet temps and turbo response. They also give a great whooshing sound!
Once installed the inlet track will no longer pass over the manifold and won't have the associated restriction like the stock inlet. These kits are designed to work without air-conditioning, if you want to remove your aircon (saves 20kg and makes working on the car a lot easier) simply purchase a non aircon belt like we have listed and contact us for instructions. You can fit these with aircon but you will need to grind away the chassis plate to allow enough room. If owners experience boost creep then please port your wastegate to suit although this will depend on your current spec. If you are unsure on how to port without taking the turbo off then please get a professional to do so (30min job). Owners can expect to see a 5-10bhp increase with these kits, a huge power hike for such a light car!
Kits will also work with both top mounted coolers and front mounted coolers, with the grill in place. Direct fit for the OEM CT9 and our own Hyrbid CT9 units. If anyone has any questions don't hesitate to ask."
Hope you like them everyone :lol:
Best Regards,
Toby
