Spoonz Posted May 14, 2008 Posted May 14, 2008 Sup.Ok so after my oil line blew of i nailed a bearing replaced it today crank didnt look like it need regrounded started her up and sounded good then it started to knock a little gave it a few res has i thought well if something is gonna happen i mite aswell make it happen will it started to knock again grrrrrr.Took it all apart the same bearing went turns out there was a small file in the crank which i didnt notice and killed it of. has i was taking the other bearings apart to check them i broke or shud i say it fail aprt the stud for the comrod so do i have to buy a new comrod. Quote
Guest Enzo Posted May 14, 2008 Posted May 14, 2008 sorry bud i found that last part hard to read, could you try explaining what part of the conrod your on about Quote
Spoonz Posted May 14, 2008 Author Posted May 14, 2008 its ok i found a part list i can buy the stud i brokethanks for reply Quote
