JAG Posted May 28, 2008 Posted May 28, 2008 I keep getting switched between me n my bro log on wiseLoads of comments I've put arent showing up unless i refresh the page like 100 times And on the strip down the right where it says who commented last and when its completly out of wack?Is this just happening to me or is it the same with everyone else? Quote
SpeedFreak Posted May 28, 2008 Posted May 28, 2008 I have had this problem on other forums, where me and my partner both use my lapton on our own log ins. Its a pain in the backside. I havent found a cure for this problem before, be good if there is one! Quote
stylophonic Posted May 28, 2008 Posted May 28, 2008 i suspect it is something to do with the stored cookies on your computer,if you use mozzila you have to use your options bar at the top right of the screan highlighted tools and select cleaer private data. that should help you out Quote
Jozinobi Posted May 28, 2008 Posted May 28, 2008 Sorry to hear you are having issues with the forum JAG and anyone else.The problem does sound very 'browser' based rather than the invision powerboard itself as 'cookies' and stored history/private data hold all your login info and passwords etc and are mainly set by the browser itself.I use Firefox myself and havent had any problems mate.Try what stylophonic suggested and see how you get on.What happens with the strip on the right you mention sounds crazy tho.If there is anything else that seems out of the ordinary please let us know.We will do our best to help buts its not easy when we havent experienced the problems ourselves to find a fix Altho Im sure its just a small setting tweak somewhere.Cheers Joz Quote
Starletraje Posted May 28, 2008 Posted May 28, 2008 I keep getting signed out everytime i come for a look! Never used to happen.i had that problem. seemed to cure by setting a button in my favourites bar to bypass the front pagewww.ukstarletclub.com/forumstry it n see if it works. Quote
JAG Posted May 29, 2008 Author Posted May 29, 2008 Never had any trouble before n its ok now Ws just yday for sum reason :angry: Quote
