Going to buy a silver sparco harness. Should i get bolt in harness or clip in harness for my 96 glanza? Is clip on the one you gotta have the bolt with the "o" ring on the end of it? I just want to put it in straight away without having to get stuff to install it.
Is there 4 bolting point for the harness in the glanza like 2 in the front and 2 in the rear?
M
Pretty sre they come with the "o rings" but that way you need to remove your rear seat belts to bolt them in
Before I stripped mine the harnesses were clipped onto a little rail that is part of the rear bench part of the seat, not sure if it would pass MOT like that though
