Hey all if you can see my starlet (avatar i fink its called) i wanted to tart up the exterior lighting the body is a dark green colour.......just wondering would it would suite the following and a rough total cost for parts inc bulbs for doing the whole lot :)
glanza headlights (smokey ones not frogey)
clear side repeaters
clear side light lenses?
would the glanza headlights just bolt on without any modification?
Its all good, you have posted in the right section.
For the record, the only straight swap headlight for your ep91 n/a starlet is the crystal clear headlights.
If you want Glanza ones then you will need the whole glanza front end conversion because the glanza headlights are longer.
Even then, the glanza headlights will be plastic, whereas the crystal ones are glass.
There is a set for sale in the parts for sale section, be quick...
Hope this helps.
Joz
Hope this helps.
Joz
Yep i've got a set Crystal headlights available in mint condition.
There 95gbp shipped to the UK.
we can also source crystal headlights from japan shag, we take payment once they've reached the uk (only require a deposit for bidding). ;)
