Asad Posted July 17, 2008 Share Posted July 17, 2008 Hey all if you can see my starlet (avatar i fink its called) i wanted to tart up the exterior lighting the body is a dark green colour.......just wondering would it would suite the following and a rough total cost for parts inc bulbs for doing the whole lot glanza headlights (smokey ones not frogey)clear side repeaters clear side light lenses?would the glanza headlights just bolt on without any modification? Quote Link to post Share on other sites
ad_starlet Posted July 17, 2008 Share Posted July 17, 2008 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...E:X:RTQ:GB:1123that what u after fella ? clear side repeaters motor world Quote Link to post Share on other sites
Jozinobi Posted July 17, 2008 Share Posted July 17, 2008 Its all good, you have posted in the right section.For the record, the only straight swap headlight for your ep91 n/a starlet is the crystal clear headlights.If you want Glanza ones then you will need the whole glanza front end conversion because the glanza headlights are longer.Even then, the glanza headlights will be plastic, whereas the crystal ones are glass.There is a set for sale in the parts for sale section, be quick...Hope this helps.Joz Quote Link to post Share on other sites
MikeN Posted July 21, 2008 Share Posted July 21, 2008 There is a set for sale in the parts for sale section, be quick...Hope this helps.JozYep i've got a set Crystal headlights available in mint condition. There 95gbp shipped to the UK. Quote Link to post Share on other sites
ecksjay Posted July 21, 2008 Share Posted July 21, 2008 we can also source crystal headlights from japan shag, we take payment once they've reached the uk (only require a deposit for bidding). ;) Quote Link to post Share on other sites
