*** Group Buy - Toy Tuning Uprated Poly Urethane Engine Mount Bushes - Group Buy ***
GROUP BUY
*** Toy Tuning Uprated Poly Urethane Engine Mount Bushes ***
(Click to enlarge)
Pricing:
Full Kit (All 3 Mounts) - £99.00 Inc VAT & Delivery (Mainland UK Only)
Individual* - £39.00 each Inc VAT & Delivery (Mainland UK Only)
Please contact us for a delivery quote if you are outside of the UK mainland.
*This is best suited for owners that would like to replace the gearbox mount only although for best results we recommend all three.
Application:
All Models
Description:
Toy Tuning Uprated Poly Urethane Engine Mount Bushes replace the your original rubber bushes with Poly Urethane, a much stronger and more durable material. These will reduce weight transfer of the engine improving torque, traction & engine response. They will also increase chassis rigidity, steering response and will reduce the dreaded wheel hop, a huge problem with the Starlets on launches.
These are an ideal replacement for your original OEM worn rubber engine mounts, these also make a good alternative to the mildly uprated TRD rubber bushes which still suffer similar problems with a considerable saving cost wise. The main problem with rubber engine mounts is that you get a lot of play from hard driving and heavy launching. When the engine torques over, it puts pressure on the mounts before it goes through the wheels. Once the engine mounts are pushed to the limit the wheels start turning. What happens is that the engine bounces violently causing a little more power to hit the ground (from the tension in the bushings) which in turn causes the car to hop.
Most Starlets out there are driven fairly hard and the rubber mounts soon perish causing excessive strain on the drivetrain, poor driveability and reduced rigidity. We rebuild a lot of Starlets and 9/10 the engine mounts are in very poor condition so these are a great option for those who want to improve on their current setup. Ideally you want to replace all three bushes although replacing the g/box mount alone will make a massive difference as this mount sees more stress than the other two. If you want to feel the biggest improvement then replace all three at the same time. These are fine for street cars, track day cars and qtr mile cars. You will feel a little more vibration on idle but no more than installing an engine torque damper or engine brace. If you have a circuit only Starlet then please contact us to discuss solid engine mounts as these still retain some flexibility making them suitable for the majority of the market.
The Full kit includes all three bushes, R/H Engine, L/H Engine and the G/Box Mount. Installation of the bushes is very simple and you don't need any specialist equipment, all you need to do is remove your engine mounts, press the old bushes out and insert the new ones. Removing the old bushes and installing the new uprated ones will take no more than a few minutes. Put them back on the car and off you go!
Payment & Information:
This group buy is available for 10+ TGTT members. You can buy these via our website, if you are not registered on our website then please do so:
https://www.toytuning.com/user/register
We have a group buy section on the website where you will find the items at discounted group buy prices.
The Group Buy TT Poly Mounts can be found here:
http://www.toytuning.com/onlineshop/groupbuys
All you need to do is:
1) Go to the Toy Tuning site and log in
2) Add the item to your basket and proceed to checkout
3) Buy the item via the group buy section as you would per a normal item and that's it!
Once you've made payment add your name down on the forum and we will update the website. The normal price of the TT Mounts can be found in the Drivetrain section so that you can see the saving you are making.
For more information or for any advice please don't hesitate to contact us:
toytuning@toytuning.com - Click Here To Send An Email
Personal Message - Click Here To Send A Personal Message
Many thanks,
Toby @ Toy Tuning
  • 2 months later...
Hey guys,
Just to let you know we have sold in excess of 25 sets of these thus far, we will keep the GB open for a few more weeks then they will be back to retail price. These are a diret fit for NA as well with nothing but positive comments so don't hesiate to take advantage while you can :)
Best Regards,
Toby
1. ann_kelvin - Full Kit
2. fred - G/Box Only
3. spuddy - Full Kit
4. D3N0 - Full Kit
5. Shorty - Full Kit
6. NosydneW - Full Kit
7. Adam_Glanza - Full kit
8. slick_ep - Full Kit
9. y3Lo - Full Kit
10. Philip0694 - Full Kit
11. WallaceGlanza - Full Kit
12. steo800 - Full Kit
13. killamats - Full Kit
14. killamats - Full Kit (2)
15. gv1.3 - Full Kit
16. glanza_dan - Full kit
17. longy0710gtturbo - Full kit
18. neil - Full Set
19. Hutch - Full Set
20. keirz - Full set
21. Nwimie - Full Set
22. Anakin - Full Set
23. GT - IRL - Full Set
24. Mikey Jay - G/Box Only
