Glanza_cl Posted August 8, 2008 Posted August 8, 2008 I have had my coilovers put on and my local mechanic said now that it's lower there looks like a lot of stress in being put onto the standard drive shaft and asked me if other people put on a shortened drive shaft when lowering there ep91's?do i really need a shorter one? i'm sure if it was a common problem i would have herd or seen on threads of this happening, he also said i might get through wheel bearings more regularly as there is more stress being created as it's lower Quote
Toby@ToyTuning.com Posted August 8, 2008 Posted August 8, 2008 No such thing unfortunately. The shafts will sit at a greater angle the more you lower, he is right but as long as you don't go mad you should be okay. Worst case scenario we sell these:http://www.toytuning.com/onlineshop/drivet...tscvshubs500bhpNot really needed unless looking for silly power! Best Regards,Toby Quote
Glanza_cl Posted August 8, 2008 Author Posted August 8, 2008 No such thing unfortunately. The shafts will sit at a greater angle the more you lower, he is right but as long as you don't go mad you should be okay. Worst case scenario we sell these:http://www.toytuning.com/onlineshop/drivet...tscvshubs500bhpNot really needed unless looking for silly power! ;) Best Regards,Tobycheers Toby didnt think i would but thought i better ask. Quote
