Can anyone shed some light on how to fit an oil temp gauge, ive brought an auto gauge and the wires are like 1ft long, wht can i use to extend them and how do i fit the oil temp gauge?
Regards
Stew
you'll need to either tap the threaded sensor into the sump or use an oil filter sandwich plate to hook the sensor into.
if you just have the gauge without the sensor then you'll need to buy the associated sensor and harness.
