Hiya,
Trying to get the drive shaft out on the passengers side to replace the oil seal.
Could someone explain how on earth i get the bloody driveshaft out?
take the nut off the end of the driveshaft the big one in the middle of the hub as you see it, undo the bolts that hold the lower arm into the bottom of the suspension leg, pull it down so the sus leg comes away from the bottom arm and you should have enough to pull it out of the gearbox.
Yeah, had the container at the ready B)
Got it out in the end thanks for the advice NAthy. Was bit of a bitch to get otu as was worried about causing more damage.
Cheers
