Guest Enzo Posted March 17, 2006 Posted March 17, 2006 here makes for interesting reading if you want to keep your options opoen when choosing an uprated turbo for the tdo4 manifold,these vf wseries turbos caan be found on one scoob or another and with abit of persuasion should all mount upto a tdo4 manifold,some of them are ballbearing so should have faster spool up charicteristicspulled it off the au site, makes for interesring readings esspecialy the cfm ratingsIHI VF Turbos - explainedVF22This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and large 40 mm compressor wheel. it is much less suited for daily driving than some of the other models. Although the largest VF series turbo, the VF22 is not quite optimal for stroked engines or those who wish to run more than 20PSI of boost. Utilizes a standard ballbearing center design. Recommended for use on cars with significant modifications and where flow capacity is more important then response time. Expect flows around 490 CFM at 18.0 PSIVF23This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24 for fast response and excellent low and mid-range performance. It does not have the same top end power of the VF22, but spools up significantly quicker. Standard ball bearing center section. Excellent bolt-on replacement for the standard WRX turbo on cars without any other major modifications. Expect flows around 430 CFM at 18 PSI.VF24This turbo shares its compressor housing with the VF23 however, this housing is mated with a smaller (P18) exhaust side. The smaller characteristics of this turbo allow it to provide ample bottom end power and quick spool. This turbo is very popular for Imprezas with automatic transmissions and Group N rally cars. Not recommended for stroker engines or engines with high boost as turbo is small and can over speed. Best turbo for cars that want the best bottom end and least lag. Expect flows around 425 CFM at 18 PSIVF28This turbo came standard on the STi Version 5. In terms of overall size, it is smaller than the VF22, VF30 and VF34, and about same size as the VF23. Expect flows around 425 CFM at 18 PSIVF29This Turbo is nearly identical to the VF24, with the same compressor and exhaust housings. However the compressor wheel in the VF29 is has been changed slightly. The changes made to the compressor wheel in this model are generally viewed as improvements, and as such this unit is typically chosen over the VF24. Has a different location for the pressure hose on the waste gate actuator Expect flows around 425 CFM at 18 PSIVF30The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the same exhaust housing as the VF24 (P18) but a larger compressor side similar to the VF22. The compressor inducer is 47.90mm. The combination of these two parts results in increased output potential without the lag associated with the VF22. Utilizes a sleeve type bearing design. Although it doesn't offer the top end supremacy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models. This is the ideal turbo for the average customer looking for fast excellent mid-range performance and response. This is not a ball bearing turbo as it utilizes a sleeve type design. Expect flows around 460 CFM at 18.0 PSIVF34The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor inducer size. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is a more recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30. Expect flows around 460 CFM at 18.0 PSIVF35The VF35 utilizes the same compressor housing as the VF34 however it also features a divided thrust or offset ball bearing design. The smaller P15 exhaust housing for quicker spool up and a slightly more limited top end. The compressor inducer size is the same as a VF30/or 34 turbocharger. you could also try a TD05 off an early wrx, They are a good upgrade for the 2L RS', And they are cheap and easy to get hold of, Will make power to redline, I guess it all depends on how much boost you want top run, and what your budget is!
