RS-R Down suspension.....
they're decent, but only lower by 25mm mate, not much at all tbh, wouldnt buy them new personally as for 125quid you could get two sets of alternative springs if you were to buy used, you could get a fixed height shocks/spring set for not much more.
Thing is, i have to keep practicality in mind the starfish is used all the time to haul loads of stuff and people around so i cant have it scraping itself all the time...so i think a 30mm MAX drop is best for me. Would you recomend otherwise?
it wont scrape mate, my glanza was approx 45-55mm lower than stock and it never scraped, it had a monster exhaust on it also, it all depends on wheel/tyre combos etc, if its used for lugging about and you wanna just lower it on the cheap then keep an eye out for used springs, they popup all the time on here and on tgtt, should be able to get a set for about 50quid that'll do the job, no need to spend 125-150quid on springs these days really if you're just wanting it a tad lower :ph34r:
It can be lowred by 40m but i asked someone on here (red na with speedlines on cant remember who it was) and they said that it did catch when going over bumps, and only rearly bottomed out with a few people in the back....
