string Posted October 29, 2008 Posted October 29, 2008 gets louder under brakingas if brakes are already engaged a little.will new discs n pads etc all round sort this?goin for uprated brakes anyway because best to sort handlin n braking first right?cheers craig Quote
Guest Enzo Posted October 29, 2008 Posted October 29, 2008 are you any good with mechanics,do you know how long you have had your pads in for, sounds like they are low or maybe rubbing metal to metal,or maybe yoru sliding pins have siezed.so you need to take the wheel of and inspect your brakes/discs to see how the pad has worn and also the nick of the discs bro Quote
