interloper393 Posted November 1, 2008 Posted November 1, 2008 Hi guys right im doing a clutch change lol, I've removed the driveshaft from the gearbox side and everything i cn see but the box wont seperate from the engine, i think I've got 7 long bolts removed, took off all the engine mounts, now when you jack up n down the whole engine moves with the box, so im stuck.. is there a guide anywhere on removing the gearbox?cars a ep91 lol Quote
Guest Enzo Posted November 24, 2008 Posted November 24, 2008 your in luck check the how2s and faq section, a guide has recenlty been posted on there Quote
GAZ@A&G_TUNING Posted November 24, 2008 Posted November 24, 2008 if you say you have everything removed, it prob just stuck on the lug's, support engine from under the sump and give te box and good wiggle or a hit with a rubber mallet Quote
Glanza_Ragger Posted November 24, 2008 Posted November 24, 2008 Look in the HOW TO section bud, as Enzo pointed out, i made a guide the other week luckily for you lol.If youve removed the rear engine mount/drive shafts and front passanger side engine mount , jack the engine up so its level and assuming you have all the bolts removed holding the box onto the block, it should pull off with a bit of (gentle) persuasion Craig. Quote
