Pretty sure the ignition timing is out a bit on the car
Feels really sluggish and doesnt rev as quit as it should/used to.
Anyone got the timing information for it?
Thanks Lewis
ok buddy this is what i have for you
start the engine and allow to warm up to normal operating temperature (top radiator pipe hot). Verify that the engine idle is correct
using a jumper wire, bridge terminals TE1 and E1 of the test connector, start the engine. the engine speed should increase to app 1000 to 1200rpm for 5 seconds then return to normal idle speed.
a )if the engine speed changes as described then ISC is ok and is idling correctly
B ) if not then er its not and you need to look in to a new ICV
if that is all ok then you need to aim the timing light at the timing scale on the engine cover, the mack on the crankshaft pulley should line up with 10- degree mack on the scale. if necessary, loosen the distributor mounting bolts and slowly rotate the distributor until th timing marks align. tighten the mounting bolts and recheck the timing
now do the check thing again
lol i think you shood just get this book :lol:
